E36 Remap
JaamesE36
Hi guys. I mate of mine has a E36 323 Touring (M Reg) I have a 323 Saloon 1997 (P Reg) he has now fitted a 2.8 into the car and given me his remapped ecu.
when I plugged it into my car (battery disconnected first etc) the car didn’t want to idle properly (idle was bouncing up and down) and when the car was revved it would then hold the revs when the throttle was removed. Is there any particular reason for this? Was there different ecu fitted to these cars? Not sure if there needs to be a reset so it all runs correctly or not
Hi James
From memory, yes it would have different settings but the requirement to 'code it to the car' from that era is not necessary.
Also from memory, I think you may have to get the ECU to learn some settings so I would take it for a drive using low, mid and high throttle settings and see if it makes any difference.
Otherwise, the sensors would all be similar so cannot see why it would not work to be fair
Let us know how you get on with it
I haven’t checked real oem but I will do. What makes life harder both cars have had engine conversion, mine was originally 316 his was originally 320. Both have 323 engines though. It was strange it held the revs and wouldn’t come back down again. Just sat at wherever the pedal was released and held it there
Check www.realoem.com it is a BMW parts list put the last 7 digits of your chassis number in the search box it will bring up your model Then get the part numbers and compare them to what you have. You will be able to see if (a) they are compatible with what you have
Then check www.realoem.com E36 323 you will be able to find engine numbers and DME numbers then double click the part number and you will see what other models they were used in
Then at least you have a starting point at the moment you are going in circles guessing
Looking at your pictures you show only part of the label the number on the right I think is the part number
Just took a quick look Basic DME  was available for E36 E39 E38 and Z3 between 1994 and 2001 part number key 1241429999 if you check realoem and click on the part number you will see all the compatible part numbers.
Do the same for the Programmed and it seems they were more specific only being available on the E36.
That is always assuming that your engine actually came from and E36 of that vintage and not something newer??
That’s what I’m starting to think. Is my engine possibly from an e39 or something like that. It’s defo the older variety as it’s single Vanos. It’s the ecu code that’s worrying me every e36 I come across tends to be 0322 and not 032 D13. Pain buying cars like this sometimes and not knowing the history especially when the previous owner bought the car already done
The codes you keep quoting are not BMW part numbers I assume they are Seimens codes but cant be sure. Have you looked at the Seimens site to see which models they were used in and how friendly they are to use? As an example I know from previous experience that often a DME needs a code entered to match engine gearbox controllers?
Here's a thought that should have occurred earlier, early cars used a Cam sensor which produced a sine wave signal for the DME later cars used a Hall Effect sensor I believe the DME will assume the sensor is in fault and not advance which would explain your lack of performance.
How am I able to tell the difference between the 2 I don’t have any faults for cam or crank sensor. Only faults I had was o2 sensor heater but the wiring and relay was missing can’t find it anywhere. So that explains that. Other code I had was for MAF. Fitted a new working maf infact fitted a few known workers and it made the car as slow as a 1.0 micra
If your engine is an early version (pre 2001) the part number on the Cam sensor should read 12141703221 or 12141730028 as far as I can tell. If the o2 sensor wiring is missing then the DME will be confused on mixture settings so may have a "limp mode" setting I don't know if that can be over ridden or over written to give you performance back.
As said in earlier posts 160/170 bhp in a stripped out shell should feel pretty lively just another thought the CAT isn't clogged is it?
James
I have been talking to an old friend who is still heavily involved with BTC cars about your issue. He tells me that the tuners liked the early 323 engine as it was so strong, but pre 96 cars the DME had to be chipped post 96 cars the DME is programmable his thoughts were if someone has tried to flash an early DMEit is probably fried. His tuning tips are M50 manifold with 325 throttle body with a ram air intake (heat shielded) then a 328 twin pipe exhaust decatted, with all mods done then remap he recons that should give a solid 200 bhp with better top end. Also consider a change of Diff to 3.15 or similar it will improve acceleration.
My own tuning experience is mainly with Ford engines (4, 6 and 8 cylinder) and some Turbo charged Volvo and Subaru's (wifes Perrin Outback). My road/daily drive is an X5 4.6 V8 rebuilt 4 years ago so added Dinan Cams and throttle body 360 whp gets me around nicely.
The car has a 3.15 diff already and a 328 twin stainless exhaust. No cat which goes to a 36 m3 Backbox. I shall check the cam sensor and see what the part number is. I know it’s a single Vanos engine not sure if that makes a difference but I will check. I’m new to BMW. Much like yourself I have a 106 GTi which I’ve had for 8 years as a track/race car and I know those inside out upside down and an astra VXR as a daily around the 300bhp mark. These BMW’s are new to me. I replaced the cracked manifold on the weekend and I think the car feels better. May be placebo of course
i also noticed when when I took the manifold off, the first manifold (towRds front of car) has a bolt which I can imagine where the first o2 sensor goes maybe? There’s an o2 sensor in lower parts of each manifold but on one of the header branches there is a blank in place?
Are they there just to plug the hole? I thought you said earlier the wiring was gone?
I just had a quick look at realoem (see attached)it looks as though you should have 3 sensors 1 in each manifold and the 3rd after the cat so if the wiring isnt there I understand plugging them probably the rear one was left just as a plug as well?
Interesting I looked at the engine electrics and there was the option for either a programmed DME (can be mapped) and a Basic DME has to be chipped so in theory your friends remapped DME should operate though if he had it in a road car it will be looking for O2 sensor input.
323 exhaust front section.pdf 323 inlet manifolds.pdf
The wiring that’s missing is for the relay, for the o2 heater wiring and relay. There’s usually 3 white relays in the fuse box right infront of the DME. I have 2 which is why I have the o2 heater circuit fault. No wiring with no relay means no heaters.
In terms of the ecu, do you know the part numbers for the programmed or chippable ecu? The remapped ecu started my car but when the car was revved it held the revs to wherever the throttle was released until the car was turned off and back on again.
Bit of an update on this. Messaged to get the remapped ecu to work. Car is completely different. Feels so much more lively now! Whilst car was running unplugged TPS and plugged back in and it idle has it should. Had every fault code under the sun. Cleared codes and they come straight back. Took it for a spin and all the codes disappeared. Guessing it was learning the sensors etc. Have a couple of codes still one of them being MAF which I didn’t have before but it drives so much better. Will try unplugging the maf or cleaning it and see how it goes but was drifting in 2nd gear in the dry no problem at all which for the first time ever in this car was a huge improvement
Thats good news
Part numbers for the Basic unit
Supersedes:
12141429861
(09/01/1996 — 08/05/2015), Exchangeable retrospectively
12141429895
(06/01/1996 — 01/28/1997), Exchangeable retrospectively
12141432401
(02/26/1996 — 09/19/1996), Exchangeable retrospectively
12141429472
(11/01/1995 — 07/09/1996), Exchangeable retrospectively
12141429373
(07/24/1995 — 03/25/1997), Exchangeable retrospectively
12141427704
(04/27/1995 — 12/09/1997), Exchangeable retrospectively
12141427703
(04/27/1995 — 10/25/1996), Exchangeable retrospectively
12141744711
(01/01/1995 — 05/17/1995), Exchangeable retrospectively
12141744598
(01/01/1995 — 05/12/1995), Exchangeable retrospectively
12141744897
(09/01/1994 — 12/16/1994), Exchangeable retrospectively
12141744160
(09/01/1994 — 05/02/1995)
Part 12141429999 was found on the following vehicles:
Part numbers for the Programmable
 No.DescriptionSupp.Qty From  Up To Part NumberPriceNotes  iThis part number is not available for
orders, and is only used to determine
the
part number of a programmed control
unit.
This is required to complete the
exchange procedure in ISTA(P).For vehicles with
Special motor
S961A=Yes01Exch. control unit DME programmedMS41.0101/199912141430434For vehicles with
National version Belgium
L811A=Yes01Exch. control unit DME programmedMS41.0109/199812141437537For vehicles with
Catalytic converter
=Yes01Exch. control unit DME programmedMS41.0101/199912141437535
Often after market air filters are Oiled the oils gets onto the the hot film MAF sensor so cleaning may work, fingers crossed
      Failed turbo
    2. 27
      325i push button start switch
    5. 5
      Transfer Case
    • bill gall earned a badge
    • SGP earned a badge
    • Kandry earned a badge
