Please Help! Engine problem!
Hi Richard Welcome to the Forum Sounds like BMW have decided you shouldn't go near any dirt or mud in your 220i Touring 🤣 That leaves little choice really. have you thought of checking Mud Flaps from either the 1 series or 3 series cars it may be they can be modified to fit ? If not it means the after market accessories have you Googled to see what if anything comes up Good Luck with the search Dave -
Can anybody help with the parts numbers for the latest 2 series Active Tourer U06 220i model mud flaps. I have tried BMW UK parts direct and they say they don't exist. Any help would be appreciated. -
Hi Stuart Welcome to the Forum Mtec with Mintex Pads always good value as are Apec, then there is Brembo discs and pads It depends if your only doing the Front or the whole car there are often some good deals to be had. Don't ignore your Dealer they often can be competitive and don't think the Auction sights are always the cheapest check the Factors as well. Use www.realoem.com to get part numbers and then use Google to find the best deal Good Luck Dave -
Could anyone recommend a decent budget set of disc brakes and pads for my 330i tourer please? -
Centre console iPhone charger
Morning Rob Welcome to the Forum Our son inlaw has an Induction charger in his 3 series it looks very "OEM" and seems to work well. It sits below the radio centre console where the ashtray would be I don't know if it was in the car when he got it or if he had it fitted ? I will ask him and let you know Dave
