Speedo is not working
Dale
Hello, I’ve recently brought a Bmw e83 x3 and the speedo is not working the Rev counter does but the speed registers 0. I was wondering if this is a common problem and if anyone could help me that would be greatly appreciated. Thank you.
Hi Dale
If you have ABS and Traction lights on then almost certainly that's the culprit.Did mine a few years ago from memory OEM was about £30 for the sensor, check the reluctor ring is clean and not clogged with muck and rust.
  • Thanks 1
    2. 5
      Transfer Case
    3. 5
      Transfer Case
    5. 5
      Transfer Case
    • Julian4285 earned a badge
    • Bertiefor earned a badge
    • lucas earned a badge
    • B10Neil earned a badge
