Door seals
brian155
Hi all, iv'e got a 2058 bmw318i e91 and need to replace the door seals does anyone know where I can get some from or how much are new ones from bmw I live in the Stafford area thanks in advance for your replies Brian.
Morning Brian
Have a look at www.realoem.com put the last 7 digits of your Vin Number in the search box and it will bring up your model. Then look in Vehicle Trim (from memory) you will see small exploded drawings with numbered parts look up the part number that will ensure you get the right part for your car. I changed the drivers door seal on my X5 cost was £45 from memory.
    4. 0
    5. 17
      Massive sudden oil Loss
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
    • Mansur Lalji earned a badge
