Steering sensor fault
Johnoc
Hi. I have plugged in my scanner and when I go into the steering angle sensor information I am getting no change in the degree of steering angle when I'm turning the wheel. I was getting a reading of 727 degrees and no rotation rate.
I cleared the steering angle sensor fault code and calibrated the steering angle sensor and the DSC light goes off. If I turn the car off and leave it for 5 mins the light is back on when I start the car. Can anyone clarify it it's a faulty steering angle sensor
Thanks
Morning John
The Steering Angle sensor is one of the few issues I have not had to deal with, I take it you have cleaned all the connectors/plugs with contact cleaner just in case it is a gungy joint that has a continuity failure when the system self tests at ignition on? Check www.newtis.info for BMW's test and check information.
I have read about a few folks that have had to change the sensor and there are how too's on You Tube and the Pelikan parts website (US site but good info)
2 minutes ago, Greydog said:
Morning John
hi Dave,
thanks for the advise. i will check connections. it seems strange that i am getting no voltage reading or rotation rate. i presumed as soon as i moved the wheel i should see some changes to angle, rotation rate or voltage.
john
      Centre console iPhone charger
    3. 4
      Failed turbo
      Failed turbo
    • Ste B earned a badge
    • mike1957 earned a badge
    • bill gall earned a badge
    • JCR earned a badge
