BMW G30 dipstick
Liamc
Welcome Liam
Welcome to the Forum, You ask about the 5 series but your title says 430D I dont know if they are specked differently.
My brother inlaws 535d estate does but it is 5 years old now so if I were you I would look at www.realoem.com put the last 7 digits of your vin number in the search box that will call up your model. Check if a dipstick was listed, it could be an option if the on-board system gives you level check facility.
Check www.newtis.info also if a dipstick is fitted that may give clues as to where it is hidden.
