Roof not working
Tony wilson
Hi
this is my first post
just bought a 2005 645 convertible
everything was working fine except the air con the local garage traced the fault to a sensor and aux water pump, these were changed now my roof does work.
the switches on the dash don't light up anymore, I have checked the fuses
any ideas would be greatly appreciated
tony
Hi Tony....welcome to the Club
If all of the lights are not working then it does suggest a power feed to them is not there, so your diagnosis of a fuse could be correct or alternatively it may be possible that the rheostat to alter the dimming could be at fault
Good to have you onboard
Cheers,   Trevor
      Bob Palagano
    2. 8
    5. 2
    • Congers earned a badge
    • bobpalagano earned a badge
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
