BMW X5 fitting sat nav
Hi Darrell
Welcome to the Forum , I would check on www.realoem.com to make sure you get a compatible part number for the nav unit and your model you may also need the loom. The nav needs coding to make it work I believe the codes can be downloaded. Not sure if the unit will need coding to the chassis or not but this can be done with INPA and DIS.
Good luck
