Will an M54b30 fit straight in??
Browsey
Hi guys I'm after some help. My 325 vert has died so I need to swap engines and I know it's not a lot of difference but would an M54b30 replace my M54b25 easily? Has anyone done it before?
I'm only guessing here as never done it myself but if the replacement engine is only a larger capacity then it would be done by bore or stroke and as long as you swap over as many ancillaries and components as possible then it should work okay
Let us know what you discover
Cheers  Trevor
    5. 0
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
    • Mansur Lalji earned a badge
