Headlight help
Blackpooltomtom
Looking at realoem you should have Xenon Dipped beam lamps and H7 mains. Are you sure its not the lamp because you have swapped it to the good side? If the lamp is good (works on the other side) then that points towards the Ballast or a bad earth connection that is where I would look.
Here are BMW's part numbers if it helps. The control unit is the ballast by the way.
01    CONTROL UNIT XENON LIGHT                                                   2 03/2005   63126937223
02 Bulb Xenon light with ignition element D1S 2 03/2005 07/2008 63217162862
02 Bulb Xenon light with ignition element D1 12V 35W 2 03/2005   63217217509
03 Lamp holder for Xenon lamp   2 03/2005   63117162087
