635 Abs Rear Rings
Nogaro 635
Have had the car a month now and I'm told the rear teeth on the ABS ring are worn. I understand that on the 635 you cannot buy the rings separately but you have to buy the half shaft that comes with the ring at circa £100 each side ?
Can anyone confirm? - mines a 1989 car so one of the last made so getting any from a "breaking car" would mean they are likely to be just as worn ? or can they be reconditioned?
Any comments would be appreciated. - other than that the car runs perfect.
  • 1 year later...
Hi Gil...welcome to the Forum
You can occasionally find an ABS ring of the right dimensions through some suppliers.
Here are some for other BMW models although probably quite similar if same diameter and number of teeth, etc
http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&selfil=2%2C3%2C1&mvsub=1&_mcatda=true&selvel=BMW~6%20Series~1985~-~-&_nkw=abs ring BMW 6 Series 1985
Cheers   Trevor
    2. 5
      Transfer Case
    3. 5
      Transfer Case
    5. 5
      Transfer Case
    • Julian4285 earned a badge
    • Bertiefor earned a badge
    • lucas earned a badge
    • B10Neil earned a badge
