Airflow Sensor Problem
regan w
  • 1 year later...
On 10/04/2015 at 0:49 PM, regan w said:
Hi everyone
I have a bmw 528i 1997 , I replaced the air flow sensor when I plug it in the car cuts out and won't tick over any suggestion ? Thanks
could it be the vanos ,the seals leak and it causes no power till 4 grand, that's my problem ,the forem said it was the air flow meter ,if you un plug it the car should run fine ,but if its the vanos a second hand one check as the M52 engine from e39 fits ,or get a kit of new rubbers ,but you have to be good at dismantling and reassembling,mite need to look the double over head cams
