Knocking Noise
Laurenceb
Hi, Just joined `the club` and have been reading with interest the various problems and fixes. There is some reference to knocking noises but I`m not really any the wiser, so here is the thing, I`ve got a 1999 323i touring and there is a knocking noise which happens intermittently, there doesn`t seem to be any pattern to it`s occurrence except it doesn`t happen when driving in a smooth straight line. I have had all the undercarriage inspected visually and nothing looks amiss, I had the drop links replaced as many people said that was probably the cause but it`s made no difference. When driving it sounds like it`s coming from just in front, to the right a bit and down a bit. Also the knocking doesn`t happen when driving smooth and straight, motorway for example. Can anyone help? thank you.
Hi Gavin, Had the front wishbone rear bush replaced, while it was being replaced it was noticed that the wishbone ( I saw this too, so it`s genuine) was distorted, so pulling on the bush, causing the rubber to deform. So I had the wishbone with it`s ball joints replaced as well and so far it seems to have stopped the knocking sound, (fingers crossed). The thing is now the steering wheel when you drive in a straight line is not centred, it`s turned slightly to the left. I am guessing that since the steering wheel before the work was done was centred and now it`s not, then someone has tried to disguise the `damaged` wishbone by doing something to the steering wheel, is it a simple thing to do, to perhaps take the steering wheel off and then put it back on, whether in line or not?
Would like to say that it drives much better now, smoother, quieter etc.
Disconnect the battery, then remove and re-centre the wheel ;)
Another (harder) way is to adjust both tie-rods a turn towards the nearside !
By far the most sensible thing to do is to have it re-tracked :)
      Centre console iPhone charger
    • Penguin82 earned a badge
    • Stuiggy earned a badge
    • Massivemark earned a badge
    • Ste B earned a badge
